It is currently Sat Aug 16, 2025 5:26 am
Post new topic Reply to topic  [ 53 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Mon Jun 29, 2015 6:57 am
I can see where a precisely routed ledge will serve the purpose of avoiding interference and contact with the finish thickness. Like I mentioned I use a mask. I don't like the plan of laying down material then doing more work to remove that material so the surface is pristine. Plus the chance of damaging the now completed finish. I don't contaminate the area in the first place. Anyway for many years I have just sanded a very slight bevel on the edge of bridge gluing surface. Has worked for me for many years and is invisible. If I decide to use a miniature router bit I'll have it cut a bevel as well to prevent the sharp edge from showing.
Here's how I make the masks:
http://www.kennethmichaelguitars.com/bridgemask.html
Ken Cierp
These users thanked the author kencierp for the post: jack (Mon Jun 29, 2015 10:12 am)
PostPosted: Mon Jun 29, 2015 7:15 am
Not to high-jack the OP's original thread but routing a ledge on a bridge bottom and clearling finish accurately enough so that one has a "pocket" of sorts for the bridge to be clamped into is most certainly not required AND more guitars have been built though all of time without this process than with.
On the other hand I always viewed my own guitar making as not just excreting yet another stinkin... guitar but doing the details, going the extra mile(s), and providing upgrades that were not available on your run of the mill, high-end f*ctory model. To each their own though.
We didn't invent the pocket/ledge thing and as far as I know the earliest adopter of this practice that I can recall (but I could be wrong) is Bill Collings and Collings guitars. For those in the know about Collings they are superb instruments in every respect and in my view a very good example of what a f*ctory instrument can be when the maker is a stickler for the details and obsessed with quality!
It's harder to do the ledge thing, at least the way that we do it because we take the ledge very nearly to the bridge perimeter which requires 1) the ability to see well.... and 2) a very steady hand, and 3) the chops and experience from having done this hundreds of times to get it right. It also requires the ability to understand the process and what this process seeks to improve on.
Millions of guitars have bridges that have been slapped on, clamped and glued with lots of finish not cleared under them.... and the bridge spanning the finish termination ledge making for a not-so-great bond in the area that it's spanning the finish ledge with some dependency of finish thickness in the bridge patch area too.
Bridges do lift though and one can almost expect it in the life of an acoustic guitar. For those who sell you know all too well that our clients are not always obsessed with caring for our creations with vigor.... and instead they let them dry out, leave them in hot cars, expose them to very high RH, etc. helping anything that is not perfect give way in time.
Most of all though this practice, routing a ledge and making a mating pocket in the finish does have notable advantages or Bill Collings would not be dong this on their guitars.
First far more gluing surface is available with only one method providing more gluing surface and that is clearing all of the finish under the bridge. Some very good repair guys do this and take it to the perimeter and exploit every bit of gluing surface. It works well but be a little off and it will show. Time, shrinkage, cold creep depending on one's choice of glue can all expose bare wood though which does not happen with the pocket method.
When using HHG to glue bridges or even Titebond the pocket provides a hedge against the bridge skating around on wet glue while clamping it in place which is a welcome thing.
Regarding the appearance the finish tucks under the bridge, no glue lines are visible, and it makes for a very neat and professional look.
Most importantly though and depending on what degree one takes this too nearly all wood-to-wood surface is exploited and put to work to help hold the bridge on and that's desirable, always.
It is necessary - hell no. Can a great guitar be built without this method - hell yes.
On the other hand it all boils down to what your bag is or more specifically what your value proposition is. If you are intent to do the very best work that you know how to do, always, and if you are keen to offer a level of value, attention to detail, and quality that exceeds others this is one of those things that will never be noticed, no one will ever thank you because the bridge stayed on and in place... At the end of the day though we prefer this method because we believe it to be superior to other methods, for now... things change... and we are very keen to do the best work possible at all times.
Going back to where I began... again it also depends on what your specific value proposition will be or is. If you are keen to do the details even the ones that will never, ever be noticed because.... well.... that's who you are this is a very good method and has notable benefits.
Required though? Not at all.
PostPosted: Mon Jun 29, 2015 7:34 am
First name: Greg
Last Name: Maxwell
City: Mount Vernon
State: Ohio
Agreed Hesh. I've had hundreds of guitars in my shop this year alone that had no bridge lifting issues (and several dozen that did) and I'm certain that many, even most, have a lacquer border under the bridge with no special allowance made for the loss of glue surface. Some will eventually fail, some won't. I've never been completely comfortable with these borders from the first time I learned to glue a bridge on. My own process has been worked out by trial and error with consideration given to the methods of others. On my new builds, I require a perfectly clean mating of the bridge and top with 100% assurance that the bridge isn't going to lift because of inferior glue contact. As we have seen, there is more than one way to accomplish that. Mine works for me beautifully and there was some pain involved in getting it worked out. I'm sticking with it, no pun intended!
It will probably be alright.
These users thanked the author Greg Maxwell for the post: Hesh (Mon Jun 29, 2015 8:55 am)
PostPosted: Mon Jun 29, 2015 8:04 am
Mike O'Melia wrote:
Im not sure if you are showing the efficacy of your ledge cutting jig. I do See some cuts. And they look like the ones I got. And that is to say, not very effective. I had to do a lot hand work to get it right. Seems to me part of the problem is trying to achieve an even cut at 3-5 mils around the periphery. Another part of the problem is proving it's terribly important. Seems to me I could just rough sand the edge and achieve the same effect. I get the mechanics side of the argument. I'm struggling here guys...
Note: the finish itself is soft. So is the top wood. Stuff is going to give under pressure. I use the LMI bridge clamp. That thing is one genius device. I can't believe for a minute I'm not getting a good bond. I sand the periphery of the bridge. And feather sand the periphery of the finish. Is this approach going to lead to failures?
It is not a very good picture of the cuts but they do wind up even. There was a learning curve. They are almost never even on the first pass, especially the corners, and multiple passes with varying degrees of pressure are usually necessary. I can see how the free hand method would work just as well once you got the hang of it.
These users thanked the author Terence Kennedy for the post: Hesh (Mon Jun 29, 2015 8:55 am)
PostPosted: Mon Jun 29, 2015 10:02 am
Can you guys tell me what exactly you are using for the masking tape under the bridge?
Formerly know as Mandodiddle.
These users thanked the author Bill Higgs for the post: jack (Mon Jun 29, 2015 6:59 pm)
PostPosted: Mon Jun 29, 2015 10:09 am
To make masks I use 3M green from the auto paint store.
Ken Cierp
These users thanked the author kencierp for the post: jack (Mon Jun 29, 2015 10:10 am)
PostPosted: Mon Jun 29, 2015 11:42 am
Joe White turned me onto to Fishers Film which can be found in art supply houses, great stuff. One of the advantages of Fishers is the thickness is predictable and consistent which is desirable of course.
PostPosted: Mon Jun 29, 2015 11:43 am
Frisket film, Matte, low tack.
These users thanked the author Colin North for the post: Hesh (Mon Jun 29, 2015 12:47 pm)
PostPosted: Mon Jun 29, 2015 12:00 pm
Fishers Film --- I think its made by 3M I am going to give it a try, I assume it stays put when applying the first coats which is a problem with some tapes when using nitro based coatings.
Ken Cierp
PostPosted: Mon Jun 29, 2015 12:23 pm
Colin North wrote:
Friskit film, Matte, low tack.
That's it! Thanks Colin!
Ken I've used it with nitro and it stays down fine and better still does not leave any adhesive on the bridge patch but I would scrape anyway just prior to gluing.
PostPosted: Mon Jun 29, 2015 1:16 pm
I'm looking for a tape to place on top of a waterbase finish (EM6000) to outline the bridge that won't pull/damage the finish when removing. Any suggestions?
PostPosted: Mon Jun 29, 2015 1:30 pm
Frisket film low tack as above maybe, but it might be a bit delicate at 2 thou thick - depends on what you want to do with.
Do you want to protect the finish on the top while removing it from the bridge area for gluing?
PostPosted: Mon Jun 29, 2015 1:47 pm
I want to draw an outline of the bridge on the tape. Score a line just inside this drawn line on the tape. Remove the tape inside the scored line. Then route away the finish inside the scored line. (Using the tape left outside the scored line to rest the router base on.)
These users thanked the author Bill Higgs for the post: jack (Mon Jun 29, 2015 1:54 pm)
PostPosted: Mon Jun 29, 2015 2:01 pm
Bill two things: First I would test on scrap. I never used this film on top of finish, any kind of finish so I would test first.
Second what I did was trace the bridge on top of the film and then cut off the excess film but, and here is the difference, before the finish was sprayed. Then I sprayed over the tape and after the finish had cured carefully with a single edged razor removed the film and it always came up very clean with no issue. Doing it this way avoids any concern for the adhesive eating the finish regardless of what kind of finish it was/is.
PostPosted: Mon Jun 29, 2015 5:44 pm
Last Name: Denvir
City: Baltimore
State: ON
Zip/Postal Code: K0K 1C0
To take the discussion in a very slightly different direction, can you mask the bridge location when you French polish? I'm guessing the rubbing would mess up the mask to the point where it wouldn't work at all.
Am I wrong?
As always, thanks in advance.
PostPosted: Mon Jun 29, 2015 6:02 pm
Yes and I really like this process
https://www.youtube.com/watch?v=lsGTJlLACYg
Ken Cierp
PostPosted: Mon Jun 29, 2015 6:21 pm
Last Name: Kincheloe
It will accumulate shellac at the edge of the mask, but otherwise doesn't cause any trouble. Just make the mask a little undersize, and you can chisel or route away the ridge the same way that you'd clear the whole bridge area if you hasn't masked it.
I use a paper mask, with a few bits of blue masking tape that I've stuck on my arm a couple times to de-sticky.
These users thanked the author DennisK for the post: jack (Mon Jun 29, 2015 6:54 pm)
PostPosted: Mon Jun 29, 2015 6:48 pm
I have always used low tack drafting tape in liberal amounts. No issues on many guitars with water based, nitro, and cat urethane finishes. Never tried with shellac/French polish.
These users thanked the author Terence Kennedy for the post: jack (Mon Jun 29, 2015 6:53 pm)
PostPosted: Tue Jun 30, 2015 8:53 am
Last Name: Minch
City: Chestertown
Zip/Postal Code: 21620
My daughter, a repair tech in Brooklyn, learned of a cool tool from one of her "old guy" mentors. It is called a mezzotint rocker and is used to roughen up the surface of an engraving plate so it holds more ink. He uses it to "pulverize" the lacquer under a bridge for easy removal. This is what it looks like - this one is 1/2" wide:
https://www.flickr.com/photos/ruby1638/18531834688/in/album-72157654016889888/
Here is a page from his site - look halfway down:
http://www.lutherie.net/B-25_bridge2.html
Here is the company site and page:
http://www.eclyons.com/index.php?main_page=index&cPath=12
Note that it looks just like toothed plane blade, and if you have one you could cut it down, or order one like this and put a handle on it. Highland has them in all sizes from 1/2" wide on up:
http://www.highlandwoodworking.com/palmplaneblade275mmtoothed.aspx
My daughter's - in the first pictures - is 45 teeth per inch and she loves it but says she would get fewer teeth per inch if she had it to do again.
Ed
These users thanked the author Ruby50 for the post: jack (Tue Jun 30, 2015 8:58 am)
PostPosted: Sun Jul 05, 2015 5:53 pm
Bump
Max Bishop
Brighton, Michigan
PostPosted: Mon Jul 06, 2015 11:55 am
Great idea, a worthwhile tool to have around. Lee Valley also has toothed blades available for their detail palm planes that are good (I have the toothed blades and the palm planes). 1/2" Wide so about the same size as the Ibex.
http://www.leevalley.com/US/gifts/page.aspx?p=67716&cat=1,41182
PostPosted: Mon Jul 06, 2015 3:45 pm
Last Name: smith
City: hemet
State: ca
Zip/Postal Code: 92543
Research done by the US showed that a toothed glue joint was not as strong as a smooth one. It may be good enough for a guitar bridge but why spend the money on one?
PostPosted: Mon Jul 06, 2015 4:19 pm
Wednesday I agree and that's been posted here before but I think in this case Ed's daughter who is a friend of ours too by the way is advocating the use of the tool not to tooth a glue joint but to get old lacquer to lose adhesion and flake off. I could be wrong but that's my read of the post above.
It's a cool idea for that!
PostPosted: Mon Jul 06, 2015 6:56 pm
Hesh, that was the way I read it as well.
These users thanked the author SteveSmith for the post: Hesh (Tue Jul 07, 2015 6:50 am)
PostPosted: Thu Jul 09, 2015 2:48 pm
Last Name: smith
City: hemet
State: ca
I understood that the purpose was not to surface the wood but in removing the finish texturing would be inevitable I would think.
